Import large .dwg file into Fusion
So, I have this 5MB .dwg file, that I want to open in Fusion 360.
This does not seem to be possible.
I have a (to my idea) decent laptop, tried all these things to improve performance and still am unable to open my file.
Is there a maximum to what I can upload?
What Fusion shows: A blank page, with the open/thinking-bar on the downright corner, and it blinks white and black over the browser field every like 30 seconds or so. The thinking-bar does not show much, sometimes nothing, sometimes stand-still green fields. If I hover my mouse it shows the Windows-circle and if I click anything, Fusion is called unresponsive.
I have got this file externally and have allready had trouble getting it in the .dwg extention, have only Fusion to work with. Is there any viewer or so I could download to split the big .dwg and help the uploading? Or could I do other things to get the file opened?
TheCADWhisperer
What is the purpose of the image that you attached?
Can you attach image of the actual dwg?  https://viewer.autodesk.com/
Can you provide link to the dwg on your A360 drive?
Ehhr... didn't really have a plan with that picture actually, only a hope that the blak bar would tell you something.
Anyways, I have tried to upload the .dwg or the fusion design it makes from it into the viewer, but this totally fails...
Before I got the .dwg I recieved an .stp file (700mb), which I also didn't get to open in Fusion. It does not upload either, it ends the upload progress bar and then just simply sais "Failed".
I did however get it into the viewer, the thing looks like this:
I could share my file privately, but I am not able to put it on this forum just to stay here forever. I could share the .stp and the .dwg.
@TheCADWhisperer: can I send you the files through PM maybe?
