Import .fbx or .obj with colors (colors lost)
3 REPLIES 3
maik.pluem
1166 Views, 3 Replies
maik.pluem
Greetings community!
I want to import elements from other sites like Sketchfab or GraBCAD and integrate them into my projects.
Unfortunately, when importing .obj or .fbx files, the color properties are lost (other programs such as the MS 3D viewer display colors correctly so that the information must be in the files).
What am I doing wrong / how can I solve the problem?
Many many thanks!
Maik
Many many thanks!
Maik
3 REPLIES 3
TheCADWhisperer
Zip and Attach folder of example files.
maik.pluem
Thanks for the quick respond!
A simple example file is attached.
I think the question should be adjusted from "Color" to "Textures" / "Appearances" because all files with issues are .obj or .fbx files with corresponding texture files.
TheCADWhisperer
Opens with the textures in Autodesk Inventor Professional, but I could not figure out a way in Fusion 360.
