import dxf
import dxf
krzysztof_smiarowski
Message 1 of 15
import dxf
Hi
when import dxf files to fusion it always look like made from points
is there any way to import them like a line or to change them from points to lines
thanks
Replies (14)
Message 2 of 15
CGBenner
@krzysztof_smiarowski
Welcome to the forum!  This looks like the curve points on a spline.  Can you tell us where the dxf originated? Is this a shape made in AutoCAD?
I am moving this post to the Fusion Design forum to increase findability among the experts who can help you.  Good luck!
Chris Benner
Message 3 of 15
ovisopa
probably that's how it was exported, I work daily with imported DXF and sometimes it's quite a struggle to make an 3D model.
If you don;t select the lines, it still shows you the dots ? In my case it shows the dots only if I select the lines
in my case that line is a spline (I sometimes clean the design using CamBam, also this shows me what tipe of line is: spline, polyline, line, arc)
I still "hate" Fusion360 for still ignoring all the texts found in dxf file, it's incredible, I haven't seen once a text imported from an dxf file 😞
Message 4 of 15
g-andresen
uncheck points
günther
Message 5 of 15
i unchceck this but it made change only "visible" because the dxf is still made from dots not from one line and when i want move or copy dxf there are to many objectes (e.g. not 1 drawing but 20 points)
Message 6 of 15
CGBenner
Hi, I wonder if it would help others here to understand what you are working with if you shared the .dxf file here in this forum?  Would you be able to do that?
Chris Benner
Message 7 of 15
it show dots when cursor is on the line( idont need to select the line) and i can select line in some points
but still working on this later is problematic due to very high quantity of dots
Message 8 of 15
no its not from AutoCad
i made this in lightburn (program to laser engraving)
and i have problem when making a dxf with tool to contour something in picture
i look in lightburn setting to change that but cant find anything so want to look can fusion can do something with this
Message 9 of 15
Warmingup1953
A few times, forum members have asked you to share a .dxf file...Can you do that?
Message 10 of 15
yes of couse,
here it is
Message 11 of 15
HughesTooling
Your DXF is a polyline so all small straight lines no arcs or splines.
This is opened in Rhino.
And in Fusion. I don't get the point display unless I select them.
You can just select the region and extrude but it will be just a faceted shape.
Mark Hughes
Owner, Hughes Tooling
Message 12 of 15
ok thank you
so may i convert polyline into line or spline? to have not so many points?
Message 13 of 15
HughesTooling
Dose Lightburn have any other export options? SVG might be one to try.
Mark Hughes
Message 14 of 15
g-andresen
1. converted to arc (V-Carve)
2. import into Fusion
The maximum fillet is limited to 0.5mm for both variants.
günther
Message 15 of 15
Yeah thank You it looks a lot better.
So simple solution 🙂
