Import an old Iventor Project?
ecam6P6WJ
Message 1 of 22
ecam6P6WJ
I tried to upload a complete project via Fusion hub. I use different approaches for that .. only folder and next try only file.
I see the DWG file in fusion, I also see that there is something in the file. But then, when I choose create a fusion design, I only get a file with an component tree of empty components. I also tried to upload it direct to fusion - same behaivour everything is empty. After that I installed Autodesk DWG TrueView 2016 there I am able to open the file - I see the whole model. So I tried to convert it to a newer DWG version. But the result was the same in fusion ....
So Is there a way? thanks
Replies (21)
Message 21 of 22
ecam6P6WJ
So now I checked in my old documentation and I am 100% clear that I created the files with Mechanical Desktop. So the file before was converted - I think that was the problem.  So this is the original one.
Message 22 of 22
ecam6P6WJ
But it should be possible as I read here. https://knowledge.autodesk.com/support/inventor-produkte/learn-explore/caas/CloudHelp/cloudhelp/2016...
So now I uploaded the project to github - i would be great if someone can try to convert it for me.
https://github.com/mgiaco/ecam
Many thanks.
cheers
mathias
