Import an old Iventor Project?
I tried to upload a complete project via Fusion hub. I tried different types (only folder and file). After that I try to open it in fusion 360. I see the dwg file there, I also see that there is something in the file. But then when I choose create a fusion design I only get a file with an component tree of empty components.
I also tried to upload direct to fusion - same Zum Wörterbuch hinzufügen everything is empty.
After that I installed Autodesk DWG TrueView 2016 there I am able to open the file - I see the whole model. So I tried to convert it to a newer DWG version.
But the result was the same in Fusion....
So Is there a way?
thanks
