Import 2D sketch points
vex
vex
I've just begun experimenting with Fusion 360 for personal use. As a professional my bread and butter is AutoCAD and Inventor so those are the workflows I'm most used to.
While exploring Fusion I've been trying to find a way to import 2D point data--similar to how Inventor does it--with no luck. So I've turned to the community here to see if some one out there may be able to help answer my questions:
1) Does Fusion allow the importation of 2D point data to make splines or similar highly constained shapes (airfoil as an example)?
2) If so, where may I find the resouce or procedure to attepmt to duplicate?
Thanks!
fritter63
fritter63
vex
Yup, as soon as I posted this I saw the default script to import a csv. I'll have to play with it a little bit and see if I can get it to work for me.
Thanks!
