,igs file upload question
rovernut
rovernut
I had an item scanned and the file returned to me was .igs.  When I upload it into Fusion 360 it looks great.  Its covered in a mesh and when I rotate it the mesh goes away and see a solid model.
I need to design around this object.  What is the best way to do this?  Can I convert it to something else like .f3d?  I don't need to modify the scanned object I just need to build objects around it that will follow the scanned items contours.
Thank you in advance for your help
--ken
huszak.marcell
The type of the flye does not affect it's structure. If you want to use it as a component you need to convert it into a brep for example, but that need a lot of computer power, the easiest way is to remodell it. Hope i could help, if not send me the file in e-mail and I will try to help you with screenshots.
Student Expert
Student In Industrial Design Engineering
TheCADWhisperer
@rovernut wrote:
...the mesh goes away and see a solid model.
Visual doesn't necessarily mean that you have a "solid model" in the CAD sense of the term.
Can you attach the original IGES file here?
