If Screencast is dead then what is the alternative way to capture and record a Motion Study
Drewpan
Advisor Advisor
Message 1 of 13
Drewpan
Hi All,
I suppose the title says it all. Screencast was "retired" by Autodesk at the end of January this year.
I have just finished a model of a Steam Engine. It works great when I do a Motion Study or simply tell Fusion to drive joints and relationships.
I had a look at Animation but in order to do the same thing I would have to MANUALLY change EVERY part MULTIPLE times to get it to do the same thing. It is an enormous amount of work when all I want is to record the animation the software does automagically in the design section.
What is the alternative? How do I record my model doing what it is supposed to do?
I don't really care about rendering and such - it is the motion I want to show off.
Any ideas would be great.
Cheers
Andrew
Replies (12)
Message 2 of 13
etfrench
I'm currently using ScreenPresso.
ETFrench
Message 3 of 13
John_Wright
https://obsproject.com/
I would use this.
Message 4 of 13
TheCADWhisperer
This doesn’t sound right.
Message 5 of 13
Drewpan
So this works when I select a Joint and do an "Animate Joint Relationships". It also works when I do a Motion Study. I tried to get it to do the same thing with Animate but according to the Documentation, Animate is not designed to do full animations like these. It will explode and change view ok and move individual parts, but the documents suggest that to get it to work fully animated I would have to do something like a Stop Motion film.
What I want is a 15 second clip of the fully automated model for my Portfolio. This is why I looked as Screencast as an alternative.
I actually managed to do this one entirely without help. I had great trouble with interference with the Cylinder and Piston. It is still not 100% but as close as I could get it. All the other interferences are just screws and bolts in holes that I could fix but are not critical.
Thanks in advance for your help.
Cheers
Andrew
Message 6 of 13
jhackney1972
Attached is a little over 15 second animated GIF of your model in motion if it helps.
John Hackney, Retired
Message 7 of 13
Drewpan
Thank you. That helps a lot.
Cheers
Andrew
Message 8 of 13
laughingcreek
@jhackney1972 - what did you use to produce the gif?
Message 9 of 13
jhackney1972
I have a copy of Techsmith Snagit.  Reason you are asking?
Message 10 of 13
laughingcreek
The op question asked about alternatives to screen cast.  I'm also interested in alternatives, so was curious to know what your using.
Message 11 of 13
jhackney1972
Snagit does a great job in creating screen captures, videos and an host of other things such as markups.   It is a great product, I have used it for years.
Message 12 of 13
Drewpan
Ended up with this one.
Ta.
Andrew
Message 13 of 13
etfrench
It will probably work for your application, but it wasn't recording the Fusion 360 dialog boxes for me.  I have a dual monitor system, so that could have affected it.
ETFrench
