Hi all,
I'm trying to create irregular oval shapes as the base panel for a bike helmet design. The 2 techniques that I've come up with so far are as below:
1) Perpendicular rails (on the left as you look at the image): I've created 2 connected arc profiles along the x axis. I've then created 3 perpendicular rails to guide the loft
2) 45, 90 and 135 degree rails (on the right as you look at the image): I've created 2 connected arc profiles along the x axis the same as above. I've then created 3 rails on the 45, 90 and 135 degree angle to guide the loft
Looking to see if anyone has a better suggestion to complete a more accurate loft. Thanks in advance
