We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Ideas for creating lofts for irregular oval shapes
davidmc742
Observer Observer
davidmc742
Observer
Observer
Hi all,
I'm trying to create irregular oval shapes as the base panel for a bike helmet design. The 2 techniques that I've come up with so far are as below:
1)  Perpendicular rails (on the left as you look at the image): I've created 2 connected arc profiles along the x axis. I've then created 3 perpendicular rails to guide the loft
2)  45, 90 and 135 degree rails (on the right as you look at the image): I've created 2 connected arc profiles along the x axis the same as above. I've then created 3 rails on the 45, 90 and 135 degree angle to guide the loft
Looking to see if anyone has a better suggestion to complete a more accurate loft. Thanks in advance
davebYYPCU
I presume both these constructions haven't worked.
Loft to a point is not recommended for clean geometry.
Might be easier to Scale a sphere, non-uniform.
Split body and Shell.
Might help.
davidmc742
Observer
Observer
Thanks for the above solution, it looks useful
