I want to know most useful text commands
sha00760
Message 1 of 9
sha00760
Hey, I am new here. I want to know most useful text command lines. Like "Sketch.ShowUnderconstrained" to show underconstrain points. I found fusion 360 text command lines pdf file but these are a lot of information. I can't memorize all commands. So can you please share me most useful lines.
Replies (8)
Message 2 of 9
jhackney1972
Use the text command “Fusion.JointAnimationTime 30” to change the speed of assembly joint animation speed.  The number at the end is the number of seconds you what to use.  The command is returned to default when you restart Fusion.
John Hackney, Retired
Message 3 of 9
TrippyLighting
component.count
Message 4 of 9
sha00760
Thank you @jhackney1972 .I will use that command.
Message 5 of 9
sha00760
That may be useful command for me, Thank you @TrippyLighting .
Message 6 of 9
jhackney1972
Try typing “Fusion ?” To get a complete list of text commands.  Also type “Options ?” for another list.
Message 7 of 9
jeff_strater
A slight warning here:  Be a little careful with these text commands, if you list out all of them.  These were really never intended for customer use.  They were intended as internal debugging tools, mostly.  Some are quite dangerous and can corrupt your design.  Others simply don't work anymore.  As long as you stick to the ones that others recommend as safe and useful, you'll be fine.
Jeff Strater
Engineering Director
Message 8 of 9
sha00760
Thanks you. I will be careful with that.
Message 9 of 9
sha00760
ok thank you @jhackney1972 .
