I cant uplode my design or export it
My design is not uploding to the A360, I tryed to restart the program and to clear the upload list but it didnt worked. So i tryed to export my design to my hard drive, so that i could try to reinstall the softower or to uplode it by the browser, the problem is that i get this messege?
What i understood from here ( https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How... ) was that f3z is exactily the extantion that was suposed to suport my file. I don`t know if i got something wrong (and in this case what cann i do to ulpload andor export my file) or if Fusion is simply not working properly.
xander.luciano
Hello! Welcome to the forums.
I'm guessing that you have linked parts inside your file? You can export it to your hard drive if you right click the linked files and choose "break link." Then it will export as a .f3d file instead of .f3z
Best,
Xander Luciano
Xander Luciano
CAM Content Developer
If my post is helpful, press the Kudo button - If it resolves your issue, press Accept as Solution!
Quick Tips: When to resselect CAM geometry | Understanding Smoothing in CAM | Adaptive Facing | Online GCode Viewer
Yeah, you`re right, it worked! Just a part two now? is it possible to relink the componentes in the future? If i need to make a change in one of the componentes for exemple, i`ll have to impor it again?
Thank you so much for your help 🙂
xander.luciano
Glad that worked!
As far as re-linking, not that I'm aware of at least sadly. You can save parts out of it by right clicking -> Save Copy As
Overall though, fusion is really powerful when it comes to editing parts as a complete file. You can just hide the other components, activate the one you want to make a change on, and then re-activate the others.
Check this post and the video at the bottom for a good explanation and overview: http://forums.autodesk.com/t5/post-your-tips-and-tutorials/fusion-360-r-u-l-e-1-and-2/td-p/6581749
Let me know if you have any other questions! I'm happy to help 🙂
Best,
Xander Luciano
Xander Luciano
