I cannot make fixed lines.
7 REPLIES 7
Message 1 of 8
463 Views, 7 Replies
I do not understand why I am getting this error. Here is a link to the file: File
7 REPLIES 7
Message 2 of 8
LeonardoBN
LeonardoBN
Hi @Anonymous.
By Fixed line, do you mean constrained (black) lines? I couln't read anything from your screenshot, so I don't what is that error, but I get no one here.
Leonardo Brunelli do Nascimento
Chemical Engineer
Hi @Anonymous.
Chemical Engineer
Message 3 of 8
in reply to: LeonardoBN
You can see it in the bottom left of the screen. It would not allow me to constrain the lines.
Message 4 of 8
g-andresen
g-andresen
as I said yesterday:
This means that the sketch is constrained and you cannot add any further conditions.
günther
günther
Message 5 of 8
TheCADWhisperer
TheCADWhisperer
Bottom Left?
Or do you really mean Bottom Right?
Your image is not very high resolution?
What software are you using to capture the screenshot?
Are you using the Windows Snipping Tool?
Are you using Windows Snip & Sketch?
Are you using Print Screen and Paste into Paint?
Can you use the Autodesk Screencast Recorder?
Bottom Left?
Message 6 of 8
TheCADWhisperer
TheCADWhisperer
Message 7 of 8
g-andresen
I'm glad you explained it again.
So it should be clear at some point after several almost identical explanations (also in an earlier thread).
günther
günther
Message 8 of 8
in reply to: TheCADWhisperer
Thanks dude! This had me confused but your video helped me to understand the issue and how to prevent it in future!
