i can't find constrain
giago
giago
hi,
i need to add a constraint to a sketch, but i can't see the menu of constrain under skect dimension.
can anyone help me?
i've tried to reinstall fusion 360, but nothing. i work on a mac, it's possibile that on a mac there aren't constraints?
Thanks Giuseppe
inchul.lee
Autodesk Support
Autodesk Support
Hi giago,
Welcome to the Fusion 360 community!
Constraints command can be accessed via Sketch Pallette on the right side of the screen (depending on where you placed it).
For more information, please check the following articles:
Inchul Lee
Phil.E
When you start or edit a sketch, do you see the Sketch Palette?
If not, use File menu > View > Reset to default layout, and try again.
Here is what the Sketch Palette looks like:
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
giago
Thank You so much 😉
