I can not find my project
I was working on my project via Fusion 360, once I changed Internet from server network to my Owen router Fusion stopped opening, any way I returned back to server network, then, Fusion is opening but I can not find my project, Please Help.Untitled-1.jpg
PhilProcarioJr
@Anonymous
Just a thought but your project might not have uploaded before you disconnected from the network. Try switching to offline mode and see if it shows up, or if your in offline mode try switching to online mode and see if it shows up.
Phil Procario Jr.
Owner, Laser & CNC Creations
Mike.Grau
Hi @Anonymous,
Welcome to the Forum and thank you for asking about that.
I agree with @PhilProcarioJr, could may switch into offline mode check if you could see your design then in the data panel?
Please, keep us updated.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
I think this may be due to a cached proxy server information in your Web services folder. I included some troubleshooting steps in your original post here as well as in a direct email back to you.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Thanks for support, Problem solved.
Thanks, the problem was websetvices file.
