How would you add a chamfer to this shape?
deses12
deses12
I used a svg to extrude a shape, and as usual, svgs are tricky bastards with lots of segments and this shape has a lot of slight curvatures and so on... So I can't select the whole outline and add a chamfer.
Here's the link to the file: https://a360.co/3jwMwKX
I know that deleting faces would help, but if at all possible I would not like to delete faces and lose detail.
davebYYPCU
You have very small fillets on external corners, any possible chamfer will be limited to the radius there.
SVG is a time soak, quicker to draw in fusion.
Might help....
g-andresen
the link has no download option.
Try:
File > Export > save as f3d on local drive < attch to next post
günther
deses12
Sorry I though that sharing the public link would be enough. I've attached the f3d file now.
Thank you!
g-andresen
1. I converterted the profiles to Bezier in V-Carve and reimported it as DXF
2. Sharing first requires that you allow the download.
With a personal license, however, this option does not exist.
günther
