How to use a model as a cutting tool with an imported mesh/t-spline body?
A client gave me a 3D scan of an object (just the outside shell) and there are some features I need to model into it.
I figured import the mesh and convert to a body, model the "cutting tool" and then modify-combine-cut to modify the body, however it is not working.
There may be some fundamental part of working with bodies vs meshes that I am not understanding, but any tips will be greatly appreciated.
For reference the workflow I followed is below -
Convert STL to quads
Import quads into F360
Convert to t-spline model
Insert body to be used as cutting tool
Attempt to use modify-combine-cut.
innovatenate
Autodesk Support
Autodesk Support
The combine tool is looking for two solid B-Rep bodies as inputs. You may need to convert the T-spline body to a B-rep body to be able to use the combine command. Are you converting the T-spline body to B-Rep?
Can I ask what you are using to convert your STL file to quads?
Nathan Chandler
Principal Specialist
Thank you Nathan! I knew there was something pretty basic I was missing.
I used Blender to make the conversion to quads. I did not know I can go straight from the mesh to a solid without first converting to T-Splines.
