How To Uninstall Fusion 360
oldtbone55
oldtbone55
I've not been able to get Fusion to work today after the updates so I've decided to uninstall it and then re-install it. There's supposed to be an automatic uninstall procedure that is noted in the uninstallation instructions as follows:
Note there is an automated tool in the below link to help remove Autodesk Fusion 360:
How to do an automatic Clean Uninstall for Autodesk Fusion 360
The link doesn't work. All I get is the following in a new explorer tab. The tab heading is "beehive.atuodesk.com" followed by the stuff below.
null({"url": "https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...", "caasKey": "caas/sfdcarticles/sfdcarticles/How-to-do-an-automatic-clean-uninstall-for-Autodesk-Fusion-360.html", "_status":"Ok"} )
I deleted Fusion manually but was only able to uninstall the program from the control panel. The rest of the instructions for deleting other files could not be found when I used explorer to find them. I would up deleting the Autodesk folder from the programs folder manually.
I have not idea why I was having the problems I encountered today but I will no re-install Fusion and see if works. I downloaded Fusion onto my son-in-laws computer and it loaded fine and Fusion worked as it should. If anyone out there has any idea why I was having the above issues please advise.
Thanks.
daniel_lyall
The Fusion guys say to do it like what it says in the link below
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
