How to turn a flat surface into a rounded one to avoid overhang issues ?
3 REPLIES 3
wayne67VL6
638 Views, 3 Replies
I'm trying to make a stand / foot for a bbq. The basic design works well, but uses a lot more plastic than is needed and increases print time. So I've extruded out a section, but it has a flat base (see image highlighted in yellow).
How can I convert this to an arch or angled component so that it falls within feasible range for printing without supports?
Tags (2)
3 REPLIES 3
davebYYPCU
in reply to: wayne67VL6
Select the long edges each side of the yellow mark and add a 45 degree chamfer.
Solid > Modify > Chamfer.
Might help....
wayne67VL6
in reply to: davebYYPCU
Thanks - that looks good. I'm going to try with a fillet of 10mm as well which looks like it gives a decent arch.
davebYYPCU
Fillets are better on the steep side, need supports on the higher flatter portion, top 10% of the fillet, no better than the flat surface you are trying to fix.
Might help.....
