Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to thread a series of cylinders together
8 REPLIES 8
Message 1 of 9
precisiontintusa
316 Views, 8 Replies
I'm trying to create a series of cylinders (25mm diameter and 3mm thick walls, the rest hollow) that can all be screwed together to create a longer cylinder. I have the external threads down, but I can't seem to create a cylinder with internal threads that ends up with the correct diameter. Image attached of what I have so far. I'm sure it's something simple, but I'm still learning Fusion. TIA!
8 REPLIES 8
Message 2 of 9
etfrench
in reply to: precisiontintusa
There is no standard metric thread which will give you a smooth 19mm bore and a smooth 25mm outer surface.  22mm - 2 comes close.
Decreasing the pitch to 0.5mm will work:
So the questions is do the inner and outer diameters have to be same for both?
ETFrench
Message 3 of 9
precisiontintusa
in reply to: etfrench
Thanks for the info. I would like the outer diameters to be the same, but
the inner diameters can be different.
Ultimately, these will connect with 1-5 other cylinders to create a very
long unit.
I don't necessarily need standard metric threads. They can be any style as
long as they will securely screw together.
Message 4 of 9
etfrench
22x1.5 is standard fine pitch.  It would probably still need extra support on the inside.
I'd be more inclined to use a coupling between each cylinder instead of having male and female threads on each cylinder:
This would probably be a good excuse to use the Simulation workspace😀
ETFrench
Message 5 of 9
precisiontintusa
Gotcha. I'll give that a try. Thanks for the tips.
Message 6 of 9
precisiontintusa
Would you mind sharing how to create the coupling? Still getting my bearings with Fusion,
Message 7 of 9
etfrench
Each of the parts are just simple revolves from one sketch.  Using the centerline type allows entering dimensions for the diameters instead of the radii.
ETFrench
Message 8 of 9
etfrench
p.s. Only one of the cylinders needs to be modeled.  Just make copies and use joints to connect them to the coupler.
ETFrench
Message 9 of 9
precisiontintusa
Perfect. Thank you!
Technology Administrators
