How to stop a pipe rotating in 3d print
vampiro2004
Message 1 of 43
vampiro2004
I have a holder for kitchen roll that i have designed that stands vertically on a pipe with two seperate snap lock pieces to fit round the pipe. Its desgined to save space. The problem is that it is slipping around the pipe as it is circular and so is my design. My question is what shape can i use to stop it from doing this?
I have attached the f3d file for my project
Replies (42)
Message 2 of 43
TheCADWhisperer
@vampiro2004
Are you OK with starting over from scratch - or are you looking for a "that's good enough" answer?
I see:
Move is almost always the wrong move as used by beginners.
Align that is not needed.
Offset Face(s) not needed.
Unconstrained sketches.
Fillets that could be in one feature.
Left over bits of geometry that do not appear aesthetically pleasing and I suspect are unintentional.
I also see asymmetrical geometry that I would expect to be symmetrical.
The deeper I did - the more issues I find.
Message 3 of 43
vampiro2004
@TheCADWhispererI don’t mind starting again, as you can tell I am still learning fusion this is the most complex thing I have done so far😂
Message 4 of 43
TheCADWhisperer
OK, check back in a while.
You will learn a lot from this exercise.
I will start preparing step-by-step instructions.
Message 5 of 43
TheCADWhisperer
@vampiro2004
Start a new file
Create a sketch of a 4-sided Polygon centered at the Origin on the XY Plane as shown below...
add the dimension shown...
now add a Vertical constraint between the two points shown.
What do you note about the color of the sketch after adding the Vertical Constraint?
Attach your progress file here (we will go very slow at first and then pick up speed as I see you are following along.
Message 6 of 43
vampiro2004
@TheCADWhisperer
think i got it, eveything seemed to snap to to the dimension of 49
Message 7 of 43
TheCADWhisperer
@vampiro2004
Next thing we are going to do is sketch a bunch of rectangles (one-at-a-time).
Start a New Sketch on the XZ Plane.
Sketch a 2-point Rectangle with the lower left corner at the Origin...
Right click on the Vertical line connected to the Origin and select Centerline...
You should see it change to a dashed centerline type.
Add the two dimensions shown below...
Note that when you select the Centerline that the dimension is a Ø35 diametral dimension.
Message 8 of 43
vampiro2004
@TheCADWhisperer
managed to get it, getting the diametral dimension was a bit confusing but i got there. couldnt figure out how you got it at first.
Message 9 of 43
TheCADWhisperer
@vampiro2004
I am going bird watching this morning - check back later for next set of instructions.
I guarantee you that you will be pleased with the progress that you make in following my steps.
Message 10 of 43
TheCADWhisperer
@vampiro2004
Notice that if you hover over the first dimension that Fusion indicates the variable name for that dimension is d1
Extrude the first sketch by a distance of -d1
this insures that even if we change the original size, we will always have a cube.
Message 11 of 43
TheCADWhisperer
@vampiro2004
Now Edit Sketch your second sketch (actually named Sketch3 in your file as you must have deleted Sketch2, that is OK).
Add a Horizontal line between the Midpoints of the two vertical lines...
Revolve the lower rectangular profile with the setting shown below.
Be sure, be sure, be sure to set the New Body option.
Click on the eyeball for the second sketch to make it visible again (if hidden) and repeat the Revolve New Body for the top rectangle...
Hide the visibility of the second sketch.
Message 12 of 43
TheCADWhisperer
@vampiro2004
Click on the second sketch and select Edit Sketch (the solid geometry will temporarily disappear as we are going backwards in history to make a change).
Add the rectangle shown below...
Be sure to select the Centerline and then the corner to get the diametral dimension (I think you have this figured out now).
Hide the second body...
Revolve the second smaller rectangle with Join to the upper cylinder.
Now add a Thread feature to the smaller cylinder (do not checkmark Modeled yet).
Message 13 of 43
TheCADWhisperer
@vampiro2004
Add a Chamfer to the edge of the thread for lead in ...
Now go back and right click on the Thread Feature and select Edit Feature and set to Modeled.  Must be done in this order. We have another change to make to the thread to make it easier to 3D print, but we will come back to that step later.
Message 14 of 43
TheCADWhisperer
@vampiro2004
Now hide the third body and select the Hole command and then select the top of the cylinder off-center as shown below and set the Options as shown....
Now click the Top view on the View Cube in upper right corner of the screen and then Click and Drag the center of the Hole feature to the center of the circle.
I always click off-center and then drag to center as I have seen too many instances of where user thinks they selected the center but are off by a tiny amount that is hard to diagnose the issue later.
Add a 1.5 Chamfer to the edge of the hole for lead-in.
You should anticipate the next step...
Edit the Hole feature and change the thread to Modeled.
Attach your progress here for next set of steps.
Message 15 of 43
vampiro2004
@TheCADWhisperer
Think i got it, just the thread on body3 did not seem to take the chamfer for some reason
Message 16 of 43
TheCADWhisperer
@vampiro2004
There is something fishy going on, but close to bedtime for me.
I'll figure it out tomorrow and let you know.
But if you have the time and motivation - start a new file and see if you can reproduce the odd behavior or if it works as expected on the second attempt.
Did you use the same thread parameters that I did M20x2.5
Message 17 of 43
vampiro2004
@TheCADWhisperer
I had used a profile for 3d screws that had tolerances built in thee screw thread.
I created and new desgin and it still does the same thing, unmodelled it has the chambfer but modelled it looses the chambfer on the screw
Message 18 of 43
TheCADWhisperer
@vampiro2004 wrote:
@TheCADWhisperer
I had used a profile for 3d screws that had tolerances built in the screw thread.
I didn't give any instructions like this.
For now, must follow my instructions exactly - later we can edit as desired.
Message 19 of 43
vampiro2004
@TheCADWhisperer
thats fine. sorry i messed up.
ive started again on a new project using all your stting you have given so far
Message 20 of 43
TheCADWhisperer
@vampiro2004
For some reason I did not get notification that you had Attached a new file.
Let me take a look at it and I will give next set of steps.
Check back in a few...
