how to start web based fusion360
I kept starting fusion360 with the program from the app store resident on my macbook pro.  After the change it would show me a message saying it isn't on the app store anymore.  I decided to get the proper version so I went to the fusion360 website and downloaded the current version.  It all downloaded and started fine.  The problem is that I see no way to actually start the program again if it shuts down.  I realize this is the most basic question but I can find no way to actually start it again.
chrisplyler
On Windows? Hit the Windows key, type Fusion, when the search result appears, right-click on it and choose "Pin to Task Bar," or, "Pin to Start." This will put a shortcut icon where you want it.
nick_p3dcreations
Weird. I guess it doesn't show in applications. On my computer it's in /users/*my name*/Library/Application Support/Autodesk/webdeploy/production/26093de3733e2b21e904a96c580f0fe30d66f465/autodesk fusion 360.app
And then pin that bad boy to your dock or drag it into your applications folder. Autodesk miiiigghhtt want to fix that so that the installer drops it in the applications folder automatically.
I finally saw that it did indeed drop that bad boy in the dock.  I didn't notice before and then did a bunch of file removing that messed things up but I think it is working now.
