How to simulate uniform internal pressure on a conical shaped vessel
andreotti60
andreotti60
Hello folks.
I hope to avail myself of your collective wisdom and experience with a particular challenge I face.  I have designed an air reservoir in Fusion 360 and I would like to simulate uniform pressure on the entire inner structure to determine whether this specific design and its concomitant specifications can theoretically sustain to be pressurized to 800-900 Psi given the size of its shell and tensile strength of the material used, namely Polylactic Acid (PLA) plastic with a rating of 37 MPa (370 bar).
I have located some discussions on this general topic, but these discussions usually center around a sphere.  My problem involves a conical shape.  Not being a structural engineer (my father was one but unless I use a Ouija board to speak to the dead, he is unlikely to help me), I hope you can.
Many thanks!
Gianluca
Hello Gianluca,
Hopefully this links will help and or guide you to solve the pressure on a conical shape tank.
https://www.engineersedge.com/calculators/Cone_Design_Tool/cone-design-calculator.htm
https://www.engineersedge.com/pressure_vessels_menu.shtml
An easier way to solve this would be to use the Simulation module in F360 and perform a Static Stress Analysis. However, you will need to have all the necessary material properties required by the FEA solver.
There is a Quick Tip in the F360 Blog that might help :  https://www.autodesk.com/products/fusion-360/blog/making-the-most-of-simplify-in-the-fusion-simulati...
Hope this will help you.
andreotti60
Thanks for the links. I will check them out.
Best,
Gianluca
