How to show Radius Dimension in Drawing fusion
cn50003
cn50003
Hello everyone,
I am having a problem when designing, I created a solid with the same size as the sketch above, but when I create a 2d drawing in the drawing environment, I cannot drag the arc dimensions as the sketch shows,hope everyone give instructions!!
laughingcreek
if you split the face in the model at locations where you want a dimension, it will provide you with points in the drawing environment you can use for dimensioning.
johnsonshiue
Hi! Without seeing the actual drawing, I can only speculate. I guess the target view edge (silhouette) is a spline, not an arc. You may want to make the model sketch visible in the drawing. Then you will be able to dimension to the sketch in the drawing.
Many thanks!
Software Test Engineer
