How to select parameter when entering dimension
juliangall
juliangall
If have user-defined parameters, I can perform an action that needs a dimension, and start to type the parameter name in the dimension. A dropdown list is shown which, when I've typed enough letters, just has the parameter I want.
How do I select the parameter using the keyboard? In every other app on every type of computer I've ever used, tab does this, but not Fusion 360 (Mac). What am I missing.
Julian
lichtzeichenanlage
  • Enter will select the first item, 2nd enter will confirm the dialog.
  • If you want the e.g. 2nd item press cursor down once, enter for selecting the item and a 2nd enter for confirming the dialog
juliangall
Thank you 🙂
