- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have created a parametric sketch, it looks like a zipper and I'm using it to create the cut lines for a finger jointed laser cut project. The sketch has X fixed size teeth in the middle, and an "arm" on each end so that I can copy/paste it, place it, and then elongate it with the arms as necessary to fit the part.
It worked well when using it for a horizontal cut line in the xy axis. But when I rotated it 10 degrees for a different part, the dimensions dissappear.
I tried to drag the end points and allow the constraints to rotate the sketch, but the dimensions stay in the original axis rather than rotating with the line.
Is there a way to keep the dimension measurements aligned to the lines as I rotate them?
Thanks!
