how to reset orbit pivot point on a MAC?
I read a lot of posts on the pivoting but couldn't find an answer so I'll post a new question.
The problem is this. When using the cube on the upper right, orbit is around the center of the screen, which is nice, when I use the scroll wheel however, the orbit pivot point seems to be a random point on the screen and I don't succeed unchanging it.
There seems to be a shortcut using shift key, then clicking an orbit point after which orbit with scroll wheel should be around that chosen point. I have tried many combinations and orders of shift and click and scroll and other possible options (alt, or function key) but I can't get it done. Is it maybe because I am working on a mac? and if so: what is the right way to reset the orbit point on a mac?
btw: my mouse preferences are set to "solid works"  (although the orbiting doesn't work like in solid works)
Phil.E
I have some answers for you.
Standard behavior is this:
  • When the entire model is on screen, orbit is at the center.
  • When model is partially off screen, orbit is at point closest to center.
So I think what you consider "random" might be happening when your model is partially off screen. It's picking a point for you.
To set the pivot point, there is no Shift + MMB click in SWx orbit mode. You must use the right click menu, and pick Set Orbit Center, it's at the very top of the dropdown menu.
I hope this helps, please let us know if you have any more questions.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Cool, that was it! thanks for the quick reply.
Strange that on the forum I found many shift-click replies and now one mentioned the right mouse button menu.
I think what happened is that I accidentally set the pivot point to a strange location. At re-opening this morning it behaved normally as you described and I was able to set another pivot point and (also important) was able to reset it to standard at the center.  Thanks.
