How to remove measure / inspection markings
Hi, I use inspection tool to confirm measurements, some have been removed when I hit restart while others remain. Please see attached image (marking in green) to understand better what I'm referring to exactly.
They appear either in Modelling or Rendering screen.
innovatenate
Autodesk Support
Autodesk Support
Thank you for reporting this issue!. This looks very similar to another issue that was recently fixed. In the previous issue, restarting Fusion 360 was the only method to clear the lines. I'll have to investigate whether or not the fix was released or not.
Please confirm the build number for the version of Fusion 360 installed on your system by going to the Help > About dialog. Are you running 2.0.1350?
Is this on Mac or Windows OS?
If you're running Windows, when is the last time you update the display drivers?
I would like to capture the steps required to reproduce the problem on my end. Would it be possible to record a screencast video of the issue?
You can download Screencast from the below link.
https://screencast.autodesk.com/
Thank you in advance for your help.
Best Regards,
Nathan Chandler
Principal Specialist
HI Nathan, thanks for addressing this issue.
I can confirm I'm using a Mac OS platform and the build of Fusion is 2.0.1350
I also uploaded the video to show how it occurs... https://screencast.autodesk.com/main/details/e93df49a-ef86-4f00-abf1-8fb00fff5d15
On the record... Fusion 360 is an amzing software, and I really look forward to using it, I just hope the frequent crashing is resolved soon.
Thanks, Zak.
innovatenate
Autodesk Support
Autodesk Support
Thank you for that video! I was able to track down some reproducible steps and submit this to development for further investigation.
As for the frequent crashing, have you seen the below link on optimizing setting for Fusion 360?
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-...
Thank you again for bringing this issue to our attention.
Best Regards,
Nathan Chandler
