How to remix parts in Fusion 360 ?
wayne67VL6
Message 1 of 8
wayne67VL6
I am trying to remix a part for a 3d print task. The creator provided a STEP file that I was able to import into Fusion.
If this was my own design, I would edit the sketch and change the dimension there, but I see no way to do this on an imported object.
I've attached an f3d and an STL of the file, as well as a picture of the dimension I am trying to change. I need to increase this gap by 0.8mm.
I saw an older article from 2017 that mentioned mesh to brep, but I couldn't find that option in my version of fusion.
Thanks in advance!
Replies (7)
Message 2 of 8
TheCADWhisperer
@wayne67VL6 wrote:
...but I see no way to do this on an imported object.
Simply use Direct Editing techniques.
No *.f3d file Attached.
*.stl is rubbish.
Zip and Attach the original STEP file here or the *.f3d file.
Message 3 of 8
g-andresen
try this:
günther
Message 4 of 8
wayne67VL6
I have a step file that contains all parts, but if fails to attach so I'm trying to attach a zip of it.
I'm not sure what is meant by 'direct editing' techniques.
I have now managed to find Mesh -> BREP - turns out that you have to disable history for that. I'm looking at slicing into two objects and going from there, but the
Message 5 of 8
TheCADWhisperer
Forget mesh.  Mesh = rubbish.
Back in a few minutes...  ...with video when it is done compiling.
Message 6 of 8
TheCADWhisperer
Message 7 of 8
TrippyLighting
I have no idea where that "remix" terminology originates from but in the context of CAD it makes very little sense.
This object is slightly more complex than a cube so it's easy enough to replicate with precision with Fusion 360's native tools.
Message 8 of 8
wayne67VL6
Wow - that is phenomenal. Thanks for the clear and detailed video!
