How to recreate a complex pattern?
Attached is a photo of circle patterns I am trying to achieve.
davebYYPCU
What do you want it to be,
holes in a plate?
dimples?
bumps?
pattern is fine, but picture has no dimensions
Might help...
etfrench
Screencast shows a brute force way to do this.  The center circles will need a circular pattern of lines instead of rectangular, but positioning the points will be the similar to the horizontal rows.  Just make each point coincident with a circle and with one of the circular pattern of lines.  Assuming this will be CNC'ed, you can go directly from the sketch to Manufacturing.  Note: You only need to model 1/4 of the holes as it's symmetrical on two axes.  If Fusion 360 bogs down as you get more points created, simply create the rest of the points in another file.
ETFrench
