How to "align" points in sculpt mode
Hi ! I have question in scult mode, I want to align two points of two different bodies, without using the wedge option, which creates a new body and creates some "impossible to resolve" t-spline errors, thanks by advance and I hope it was clear !
jeff_strater
If the two bodies are in the same "Form" feature (for a parametric design), just use the "Weld Vertices" command to merge the two sets of vertices.
Jeff Strater
Engineering Director
How do you do these parametric things in sculpt mode ^^'
TrippyLighting
You don't. T-Spline modeling in Fusion 360 is not parametric.
The geometry in your design so far is easier to design in the Model (Solid) workspace and there it is fully parametric.
Sorry again, so i should use sketching to do what i want "outside" of the sculpt mode, am i right ?
TrippyLighting
Perhaps you should go through the tutorials in the Learn & Support section (Convenient link provided in the top menu bar here on this forum), so you can familiarize yourself with the numerous tools in Fusion 360.
Then you'll have a better foundation for questions.
jeff_strater
sorry to have confused the issue a big, talking about "parametric design".  You didn't share your design, so I couldn't tell if it was history-based or a direct modeling design.  It matters in this case because of the way that Fusion handles Sculpt bodies in the different types of design.  @TrippyLighting is correct - Sculpt operations are not parametric themselves.  But, in a parametric design, sculpt bodies are contained in a Form feature.  If the two bodies in question are in different Form features, you cannot use Weld Vertices to join them.  That was the only point I was trying to make in referring to parametric designs.
Jeff Strater
