How to put an indent in a button
Message 1 of 9
my device has a button with a diameter of 14.8mm.
I will add a fillet of 0.1, so the diameter for the indent should be 14.6.
The indent should be like when I create a really big sphere over the center of the button and that sphere cuts in the button. This is so the finger can find the button easily.
I can calculate how big the sphere must be when I want that the sphere has a diameter of x. But that is not so precise.
Is there a tool in fusion 360 for things like that?
Or is there a trick?
Replies (8)
Message 2 of 9
TheCADWhisperer
Yes.
Coincident constraint.
File>Export and then Attach your *.f3d file here if you can't figure it out.
I seldom do ANY calculations - get lazy, let the software do the work for you.
Message 3 of 9
Does that work in 3D too?
Message 4 of 9
TheCADWhisperer
The part is 3D?
Message 5 of 9
Ah I see, you created a circle in 2d first and then the sphere. I will try that out now
Message 6 of 9
TheCADWhisperer
It could have been done with only one Revolve - but I was trying to keep in line with the idea of cutting with a spherical geometry.  The user has to define the indent depth.
Message 7 of 9
I attached the drawing. I added a construction plane and created the circle. But idk how to let the sphere mid point snap to the circle mid point 😕
Message 8 of 9
I got it. I cutted the circle in half and have created a revoke
Message 9 of 9
TrippyLighting
Please don't forget to press the green "Accept solution" button under one of the replies, so we can close out this thread.
