How to project sketches or complex shapes on a curved surface
2131dec1
Observer Observer
2131dec1
Observer
Observer
Hello, I am a student studying fusion 360 in South Korea.
Please understand that I am using a translator because I am not good at English.
When I started working on it recently, I ran into a difficulty.
The content is to create a curved surface in fusion 360 and then attach a very complex form of relief along the surface.
At this time, the relief consists of about 13 layers, which is the lowest, that is, the shallow relief-type structure and the small relief-type structure on top of it to form a single body.
The example image is as follows.
(layer1)1
(layer2)22
(layer3)333
(layer4)4444
(layer5)55555
(Body) (Body) (Body) (Body)
I'm trying to attach this shape to the curved surface by setting the thickness of each layer to 0.2mm, but I'm having a hard time fusing the bodies of each layer generated, let alone the sketch projection, into the main body.
In response, I also uploaded the dwg file that I was working on.
I would really appreciate it if you could tell me how to solve this.
Thank you for reading it.
Warmingup1953
Can you share your Fusion file?
I have used an Online viewer for the .dwg:
Warmingup1953
Is this the effect you are looking for?...a number of Embosses at differing heights?
2131dec1
Observer
Observer
Yes, currently Korea is Saturday, so I can't access my file. I'll try to respond as soon as possible on Monday. Thank you.
2131dec1
Observer
Observer
Yes, that's right. I've designated the height of the layer for each color, red, orange, yellow, etc. I've tried to create embosses with different heights, but it wasn't easy.
2131dec1
Observer
Observer
This is the .f3d file I was working on until the very end.
I'm going to make the sketch elements of [Block_0:1] different heights by color and attach them to body 1 on the left.
