Exporting model from fusion with individual face materials - hobby version
I have been trying to find a concrete answer to this question - and I can find posts from 3-4 years ago suggesting Fusion cannot do this at all... But then I have found other topics suggesting it is possible but no concrete answers how or why it may not work in some circumstances.
Basically I have a solid that I have applied materials to faces on the model. If I export as obj it has a material file, but this only includes the base material applied to the body - not the materials applied to faces. If I understand correctly this may be because Fusion cannot create a texture map.
However any solid body files (such as step) also do not export with any material information. If I reimport an exported step file it has no material properties.
I'm happy to use other applications as an intermediary step if this is possible. But I am essentially trying to get from a solid body in fusion to an obj or wrl file for importing into another application. Hopefully without having to redo the materials manually.
