How to project / flatten developable surfaces in Fusion ? (Sheet metal errors)
bernard5BABD
Message 1 of 38
bernard5BABD
I have this project of a boat hull, intended to be built using the stich and glue method, so all surfaces are developable.
Problem is, I tried everything I could think of to transform each surface into a sheet metal (thickening then extruding straight on a few centimeters), I always have an error saying that it can't calculate the thickness. Is there any other way to get those parts' shapes on a flat surface, to be able to cut them ?
Thanks for your help and advices,
Bernard
Bernard Grosperrin, Retired, Maker, and Autodesk Certified Instructor
Blog : Le Bear CNC | Forum : Le Bear CNC Forum | Addin : Airfoil Sketch from file
Replies (37)
Message 21 of 38
bernard5BABD
Yes, I know about the tiny planar face. I tried adding one. I don't have Inventor. I will try the loft flange tool.
Thanks for your help, I had no idea this would be so difficult for Fusion.
Message 22 of 38
bernard5BABD
Yes, I know about the tiny planar face, that's what I have been trying to add to the thickened surface before attempting to convert to sheet metal. I did not think about the loft flange tool, I will test it. Thanks for your help, I had no idea this would be so difficult for Fusion.
Message 23 of 38
TheCADWhisperer
To have much of any chance of getting this to work in Fusion 360 you will have to use the Fusion 360 Sheet Metal tools to model the geometry (not Convert).
I strongly doubt you will have success in this endeavor without using other Autodesk tools.
In any case - Attach your cleaned up Fusion *.f3d file for diagnosis when you get a chance.
Message 24 of 38
bernard5BABD
I just tried the loft flange tool, did not work. Contours have to be on a plane.
Message 25 of 38
bernard5BABD
Already done.
Message 26 of 38
TheCADWhisperer
Rats, I already shut down for the night.
The last file I saw Attached was Insider version - I did not realize that you had replaced it.
Message 27 of 38
bernard5BABD
Have a good night, tomorrow is another day... 😉 I m going to do the same !
Message 28 of 38
TheCADWhisperer
First thing I notice is that there are no dimensions on your sketches?
Then I noticed that you used splines in your sketches confounding the issue.
Double confounding I noticed that you used Loft (and not an overbuild trimmed Loft).
I do not think you will be successful with this geometry and in any case I would clean it up some more.
Sometimes, it's a good idea to believe what the user says,
rather than questioning his ability to know what he is saying/doing. They ARE developable surfaces...
After 36 years of experience in this business I have learned to never believe anything other than the actual geometry.  This is most definitely not a developable surface.
Preferably I could reduce the geometry into parts of tangent trimmed cylindrical surfaces well within the manufacturing process tolerance that represents the spline-based geometry.
If I were modeling this geometry and it had to be a spline-based Loft, I would used a overbuild surface and trim.  I would use Autodesk Inventor Professional rather than Fusion for the task.
I would use dimensions.
Logical dimensions.
Message 29 of 38
bernard5BABD
No, there are no dimensions on the sketches, as I scaled the canvas to the dimensions I wanted, and everything is built on them.
I have to use splines to follow the original (on canvas) design. If you know of another way, I would be glad to learn a possible alternative.
I don't understand what you mean by "overbuild trimmed loft". If you look at how this was built, I use the horizontal and vertical views to extrude surfaces (horizontal first, then cut from the vertical), then loft are made between the edges of the resulting (once cut) surfaces. Again, if you know a better way to do this, as simply as possible, I am willing to learn.
I use this method to avoid the traditional way, which would be to try to find position and shape of frames, then loft between each frame. Here, frames (not designed yet) would be the result of a simple intersection, instead of spending a lot of time trying to find the right shape. They are not on the original drawing, so this method is, from my point of view, simple and efficient. Now, once again, I would be happy to learn an alternative way to  do the same thing.
PS- I am not sure why you say these are not developable surfaces. They are. Make a section analysis from the stem to the bow, and you will see that, at every point, the side of the hull are perfectly straight lines. If Fusion "see" this as not developable, then Fusion as a problem. Like I alreay said, in real life, this plan is intended to be built using the stich and glue technique, from large sheets of multiply wood. Or we don't have the same definition for "developable".
Ps-bis: I can't afford to have Inventor.
Message 30 of 38
TheCADWhisperer
>>Overbuild and Trim Surfaces - click link<<
These spline curves can surely be built with tangent arc curves that are well within any possible manufacturing tolerance, however, by the time you get the 3D intersection curve it will be a spline.  But for simplicity of editing I would most likely use dimensioned tangent arcs.  I would use logical dimensions in my work.  I am used to measuring things out on the shop floor during construction.  I like dimensions.  Dimensions are some of my best friends.
Message 31 of 38
bernard5BABD
I totally understand what you mean, and I am sure you're right. It's just that I doubt changing this would help to solve the current problem... 🙂
Message 32 of 38
TheCADWhisperer
I am surprised that you cannot see the issue in the Loft surface?
OK, this might be doable in Fusion 360, but more care will be needed in creating high-quality geometry.
In my experience observation is key.  The issue with the Loft (as created) should be obvious (especially after it is pointed out). Try Thicken of that surface - what do you observe?
Message 33 of 38
bernard5BABD
I did thicken that surface, more than once, and I did not see anything especially noticeable. What I am supposed to see ?
Message 34 of 38
TheCADWhisperer
You did not Attach a file here with Thickened surface?
How much were you able to Thicken it?
What do you observe in my image of this Thicken?
https://www.youtube.com/watch?v=1rMxcK_No-A&list=PLp5izJt_zvN0GnwEUFR1zE06nQvDAWxz2&index=1
Message 35 of 38
bernard5BABD
I thickened to 18 mm, but I have not been zooming as closely as you show (and it's certainly thickened to more than that). OK, I will look at the video, and use arcs instead of splines.
Message 36 of 38
davebYYPCU
Message 37 of 38
TheCADWhisperer
@bernard5BABD
How are you making out?
Imagine you took a bed sheet and dropped it smoothly across your geometry.  (Overbuilt surface)
Then you trim the edges.
Now imagine that you could see the individual thread-weave. (Isocurve Analysis)
In your geometry observe how all of the "threads" on the bottom panels in one direction are "pinched" to a point (or close to a point).
(In the top image above.)
In the lower image notice how the "thread weaves" in the side panels are nice evenly spaced 4-sided with no pinching.
This is what you want.
Here is a zoomed in view...
Avoid the "pinching" of material.
I think @TrippyLighting has a good link to a more in-depth Alias reference covering this in detail.
Message 38 of 38
bernard5BABD
I started watching your videos, I will modify the design with arcs and dimensions as soon as I get some time to do it.
Where is this link ?
Again, thanks for your help. Even if I believe to have a pretty decent experience with Fusion, I realize there is still a LOT to learn.
