How to place a patter on path over a curved ramp.
Message 1 of 8
Good afternoon.
I tried to place a pattern of cylinders over a curved ramp in many ways but for profile I need to use the program says it is an invalid input setting. The path underneath works perfectly and all others. The two profiles of the ramp that I need give me the same error. How can I place a pattern over the ramp?
The 2 first images show the error over the profiles I want to use and the 2 second pictures show how the path underneath works perfectly. Why it does not work over the ramp?
Than you so much.
Replies (7)
Message 2 of 8
jeff_strater
can you share your design here?  It would be easier to investigate from the design itself
Jeff Strater
Engineering Director
Message 3 of 8
Do you mind to explain me how to do it?
Message 4 of 8
https://a360.co/2WUfiLV       Is this what you need?
Message 5 of 8
Message 6 of 8
jeff_strater
yes, that is what I need, thank you.  Will look at it once it comes across
Jeff Strater
Message 7 of 8
jeff_strater
I looked at this model quite a bit, and I admit I am stumped.  All the usual things I would try seem to fail on this design.  I created Fusion bug FUS-63033 to track this.  Sorry not to have better news.
Jeff Strater
Message 8 of 8
Thanks for your time.
Is it possible to change the title? I made a mistake, I put pattern instead of pattern and now it appears every time 😅😅😅
