- Mute
- Permalink
- Report
Quick question: I'm making a jet nozzle with a number of small holes in the tip:
The number of holes is parameterized - it makes one central hole and then the rest are done via circular pattern where the number is driven from the hole count.
How can I do this so that I change the count parameter and it automatically produces a nozzle with the new number of holes cut out of it? My sticking point here is the Combine operation requires I manually select the tool bodies. For example, if I turn the count to 6, I get this:
So I guess two things:
1. Is there a way to tell Combine "Use all the bodies resulting from these two Extrudes and this Circular Pattern"?
2. Is there a totally different way to do this that avoids this problem?
Thanks!
