how to open corrupted recovey file
gurinderjeetsingh7
Message 1 of 23
gurinderjeetsingh7
I was warking offline and on a model and it was untitled ant not saved yet. suddenly a window came that fusion 360 stops
i restart application/fusion and when i click on my recovery file there come failed to open.corrupted file.this is for second time so i want to know that is  there is any ay to open that recovery file . it is very important so please respond as fast as possible
otherwise i discountinue usiong fusion 360
Replies (22)
Message 21 of 23
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @gurinderjeetsingh7
Got it!! I will get back to you as soon as possible. 🙂
Thank you for your time Heart
Many thanks,
Ahreum.
Message 22 of 23
ahreum.ryu
Autodesk Support
Autodesk Support
Sorry to have kept you waiting. Smiley SadI received this from development team.
eda2421dfc354b018ef3b216606f1d24) opens fine. You’ll need to rename the file extension to f3d first.  (after changing the name, you are able to upload this file as normally. )
0a85019c97f94444bad14e1473f093ac.f3d complains that it is not a valid zip package. Maybe something went wrong in the creation of this file. Can’t do much about it unfortunately.
95d69c05d4fd4a6a80df937310e420c1.f3d complains about some issue loading TSpline data. The Ebony team (cc’d) probably needs to look into it.
Regarding last file, if I receive any response from them I will get back to you!
Many thanks,
Ahreum.
Message 23 of 23
gurinderjeetsingh7
Thanx....😀😁😂😄😍😍 I find my project . I renamed it and try to open it on my PC and I find my project Thanx . Thanx for your assistance thankyou so much
