- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
How does one open a previous version of a file ?
When I am in the dashbord and in the project I can click on the file and then on the clock icon in the window that pops up.
The screenshot shows that I have selected Version 71 and one would asume thats what will be opened when "Open in Fusion 360" is selected.
Howeverthat is not what is then loaded in Fusion 360. I am still getting the latest version 😕
At this time I am excited about Fusion 360 but also rather frustrated. The software has repeatedly crashed in the 4 days I've worked with it and I've posted several bug reports here on the forum. The latest problem is that the sotware crashes when I try to edit the sketch for the base extrude. the crash happens when I close the sketh, eve if nothing in the sketch is changed. This has happened with at least one other sketch.
As I wanted to change the base extrude the other approach I took was to roll back the timeline and then change the sketch of the base extrude in this state. This worked but when rolling the timeline forward at about 85% there is one step where the software crashes yet again reliably.
So a prior version is desired so I can at least try to work from that.
