How to name and reference a measurement
I have a parametrized design and I need to reference a distance between 2 lines and divide them by a parameter. This is quite easy if I can name the distance between the lines but equation can become a bit complicated if I try to write it down (I needed to draw it with pen and paper to get the formula).
Is it possible to name a measurement so I can reference it in expression?
davebYYPCU
Create Dimension, enter value as - Name = equation
Name will be a Parameter in the Parameter List.
Might help....
