How to move vertex on other plane
shuttle978
Observer Observer
shuttle978
Observer
Observer
I'm new to Fusion 360.
I drew a rectangle (2D) on the front plane, now I need to move a vertex to the right plane or another plane. The problem is that when I try to move it, The rectangle is no longer closed. How can I move the vertex to another plane? I also tried projecting the vertex, but the problem is the same.
Thank you very much.
Kent1Cooper
@shuttle978 wrote:
.... I'm new to Fusion 360. ...
Forums for Fusion are >here<.  [I've notified the moderators suggesting this be moved there.]
Kent Cooper, AIA
wersy
If I understand correctly, you are trying to turn a 2D sketch into a 3D sketch.
In a 3D sketch, profiles are not closed.
Can you show what you want to achieve in the end?
shuttle978
Observer
Observer
No, I'm on 2D view (Edit Sketch) with a simple rectangle
The rectangle is closed. If I selecting a vertex, switch to another plane (for example right), move the vertex of 5mm long Y, than I return to Front plane and the rectangle is opened.
How to move correctly the vertex to another plane?
jhackney1972
In a 2D sketch, all points must exist on the same plane if you expect the sketch to remain closed and create a profile.  This means that what you are attempting is not possible.  What is you intent, what do you need to accomplish?
John Hackney, Retired
TheCADWhisperer
@shuttle978
In addition to @jhackney1972 comments,
