How to move curve or line in Sketch
Message 1 of 13
It looks simple but I need help
see my screencast
What am I doing wrong.
regards,
Pieter
Replies (12)
Message 2 of 13
TrippyLighting
Is is possible that the point you are moving to is not in the same sketch ?
Message 3 of 13
jeff_strater
hi @Anonymous,
Can you share the model?  This seems like incorrect behavior, but there could be a number of valid reasons for this.  The model will help us figure out which it is.
Jeff
Jeff Strater
Engineering Director
Message 4 of 13
f3d added
Let me know what I am doing wrong.
regards,
Pieter
Message 5 of 13
HughesTooling
A few of observation.
One you are not in sketch edit mode, this might no matter but I'd usually want to select edit sketch first so you can add constraints, dimension etc.
Two, the white dots indicate line\curve end points are not joined so when you select that end point you might not move the curve you want to. You might want to add a coincident constraint if you want the line and spline joined.
Here's a screencast, shows the sketch in unconstrained so you will get unpredictable results when moving. I had no problem using move or dragging the endpoints in sketch edit mode or in modeling mode.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 13
You made remarks about white and black dots
Did a little practice.
first action :  creating a line
why only one black dot ?
second action : coincidenting corner top left
removed perpendicular constraint
then tried two ways to use coincident
I don't get a black dot.
WHY
regards,
Pieter
Message 7 of 13
HughesTooling
Spline points are always displayed that why your first example shows a black point at the spline end of the line. With lines\arcs when endpoints are joined the coincident constraint and point are not displayed, probably just to keep the display a bit more simple and uncluttered. If you right click near the end of a line\arc that's joined you get an option on the right click menu to delete the coincident constraint by the way.
Mark
Mark Hughes
Message 8 of 13
TrippyLighting
Here is a link to the handout on Google Docs @jeff_strater and I prepared for our class at Autodesk University.
Good part of that class was about sketching and there is a table in the doc that explains what the different colors mean called "What do all the colors mean ?"
Message 9 of 13
Thanks for your answer.
For me the curve in the screencast is fully constraint.
why is it not changed black.
any idea?
regards,
Pieter
Message 10 of 13
HughesTooling
Do you mean the ends of the spline handles? If that's what you are asking about they're not fully constrained, you've constrained the length but not the position.
Mark
Edit looking a bit closer it looks like you have angle constraints on the spline handles so it might be fully constrained. The sketch colour DOF is in preview and is not always correct.
Mark Hughes
Message 11 of 13
HughesTooling
It looks like spline handles don't change colour unless they are joined to some other sketch geometry.
Just constraining with dimensions doesn't turn black, if you add a line to one end it does.
Mark
Mark Hughes
Message 12 of 13
I added a new screencast
You can see while dimensioning the vertical and horizontal lines are turning from orange into black
the curve (line) is also given all its dimensions
Thus should change from blue into black.
I notice that it is a lot of trial and error to let a curve ( line) turn black
Message 13 of 13
HughesTooling
Like I said it's in a preview so it gets it wrong sometimes.
I have Fusion setup so curves change to white for constrained, in the image below it shows white but the spine handles are not fixed so it's not constrained.
Mark
Mark Hughes
