How to move components joined with joints
juliangall
juliangall
What am I missing here? I have seen many models that have components connected by joints, and you can drag the components in line with the joint. I am trying to create a model that does this. Here is a simple example.
I create a sketch with two rectangles, extrude the rectangles into bodies, convert the bodies to components by clicking on them in the browser and selecting "Create Components from Bodies" (one body at a time).
Then I create a joint between the components. I can create a slider, revolute etc. and the joint does a sample animation for me. I click ok.
Then what should I do to move the joint. If I grab one of the components with the mouse, it just moves both of them together as a pair joined together rigidly (my joint is not rigid, naturally).
Do I need to get into some sort of joint-dragging mode? If so, I cannot see how to do this?
Please let me know what I am doing wrong. File attached.
Many thanks,
Julian
laughingcreek
is either component grounded? (rightclick on component in browser, select ground)
juliangall
That was it. Thank you. Grounding one component did it.
Julian
jakadels
Observer
Observer
thaaaaaank youuuuu 🙂
