How to move a solid edge?
tookemtoni
Message 1 of 8
tookemtoni
How to move just a solid edge?  My intuition is to select that edge and simply try to move it.
See screen shots, video demo and f3d file. https://a360.co/41pbumB
(view in My Videos)
Replies (7)
Message 2 of 8
praise.tomWX9P2
Hi @tookemtoni
One suggestion is to use a sketch with the required profile and use the extrude option.
Please check on short screen recording click here
Regards
Praise Tom
Message 3 of 8
harv.saund
Hi @tookemtoni
You can use Direct Edit here if you know the angle which you need to move the edge by. The more accurate solution would be to do what @praise.tomWX9P2 suggested and use a sketch and extrude. I have attached a video for the direct edit if you wanted to try.
(view in My Videos)
Harv.
Message 4 of 8
TrippyLighting
If you do "that", how are you going to address the emerging triangular sliver at the bottom?
Message 5 of 8
tookemtoni
good point @TrippyLighting But it wont matter for the base on this cabinet. See screenshotFusion360_yhkiV74Oin.png
Message 6 of 8
tookemtoni
I would love to see solid modifications via edges (and points) as fast and easy as we can do with Forms (T-splines) in Fusion.  See GIF.
Message 7 of 8
TheCADWhisperer
@tookemtoni
It looks to me like totally incorrect techniques are being used to create the geometry.
Message 8 of 8
tookemtoni
Here you go.
