How to model square coil?
travis.designer.vn
travis.designer.vn
Hi
I try to replicate this model:
I model coil, then use Split Body to cut coil in 4 sides.
But There's a problem. Line is not straight.
I'm finding other method to model.
This attached file.
Best regards
Travis
davebYYPCU
And corners are a problem.
Need detail how to "match corners".
travis.designer.vn
@davebYYPCU It's hard to match corner.
I have an other idea. Not good enough.
davebYYPCU
My pic was not included.
travis.designer.vn
If I keep 5 degree and sketch 2 profile. Then Using Sweep tool instead of extrude. It will be better.
What do you think @davebYYPCU
TrippyLighting
This is fairly easy to do, but it takes a little bit of working with the loft tool:
travis.designer.vn
Thank @TrippyLighting
That's perfect corner. You usually have great idea.
