Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This is a simplified version of a design I want to carve into the lid of a box. The box is intended as a wedding anniversary gift. I want to mill a design that gives the appearance of interlocking rings. I'm not quite sure if I should be trying to use the loft command, or create a set of solid, interlocked rings and then carve away the unwanted sections.
In this test file, I want to create some slopes such that at intersection 1, ring B is carved away in a gradual slope so it appears to dive under Ring A. Similarly, at intersection 2, Ring A should be carved away so it appears to dive under Ring B.
Any suggestions? Thanks!
