- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a sheet metal part that used three separate "flange" operations early on, where it could have used a single one. The problem with the separate ones is that they do not create bend relief to the other neighbor flanges, whereas bending them all at the same time will create the relief.
So, it would be great if relief could take previous bends into account, BUT that's not what this post is about. Instead, I now want to undo this problem, by creating a single blend of three flanges.
Unfortunately, these flanges are quite important base features for further features -- when I suppress them, a whole slew of other work also becomes suppressed.
So, what I would want to do, is to re-parent the dependent suppressed features to the new flanges created by inserting a unified flange to replace the three separate flanges.
Is there any way to do this? I can't find any.
Also, when working on this, if it was possible to color certain features in a contrasting color, it would be easier to at least figure out which features need re-creation when doing this resolution. In general, some better way of diffing and exploring the feature timeline would be quite helpful. I know I can rename individual operations, but those names aren't very visible...
Is there some feature here that I'm missing, or is Fusion just not particularly good at this workflow?
