how to make this texture like this?
atomleef
Message 1 of 24
atomleef
I want to make a model with this kind of texture. How to make this texture?
thank you in advance 🙂
Replies (23)
Message 2 of 24
JHRendon
You could make the cylinder and then a cut with the sweep tool. Make some fillets and circular pattern.
or maybe in sculpt workspace. 🙂
Message 3 of 24
atomleef
thank you
Message 4 of 24
TrippyLighting
Can you demonstrate that?
Message 5 of 24
JHRendon
Maybe later. Let's see if the guy can figure it and make it by himself. 👽🖖
Message 6 of 24
atomleef
i try with circle as you suggest. Now i got straight texture. After this step hot to rotate the texture?
thank you
Message 7 of 24
JHRendon
The path should not be straight, it should follow the trajectory you want. You can use Spline. Then project that sketch on the surface. 🙂
Message 8 of 24
TrippyLighting
@JHRendon how about a screencast to show how you would do it?
Message 9 of 24
JHRendon
If you do not know how to project a sketch on a surface, watch this video (min 30). 🙂
https://www.youtube.com/watch?v=bap8IO92jrM
Message 10 of 24
atomleef
thank you
Message 11 of 24
TrippyLighting
@atomleef here is a screencast showing how this can be approached in T-Splines. Not exactly what you are trying to create but it should give you a good idea of the general approach.
I personally would do this in Blender with the array modifier as that makes controlling things easier without having to select faces/edges all around the body, but you can also create selection sets if you want to re-select a set of edges/faces.
Message 12 of 24
atomleef
after i use sweep tool the start point and end point doesn't have same size of texture. How to resolve this?
please see attachment
Message 13 of 24
JHRendon
That would not happen. Mmm.. check the geometry you are sweeping if all is right. Maybe using loft could have better results.
Message 14 of 24
TheCADWhisperer
Message 15 of 24
JHRendon
Here is the line on the surface.
Message 16 of 24
atomleef
i just found out the parallel and perpendicular option in sweeping it work great with project line to surface.
thank you  so much 🙂
Message 17 of 24
atomleef
Firstly i sweep as straight line instead of project line then it came out as first screen shot. Now i use project line it work great now.
thank you 🙂
Message 18 of 24
TrippyLighting
That approach is going to create superb geometry 😉
Message 19 of 24
JHRendon
Idk what wrong with you. That file is to tell him how he can make that curve... is not exactly the path he wants.
focus on helping people, not in attack to other users who try to help. 👽🖖
Message 20 of 24
LeonardoBN
What I can't understand yet is how an apparently nice and inoffensive curve can have that curvature comb.
This remembers me about some examples of Horizon Modeling in Fusion. They seem to be perfect at first sight, but Patch surfaces can have a strange curvature.
Leonardo Brunelli do Nascimento
Chemical Engineer
