How to make pocket toolpath follow edge of model
rj_gould
rj_gould
I'm struggling with getting a pocket toolpath to do what I want.
The goal is to clear out material on the inside of this model
But along the upper edge, the toolpath runs perpendicuar to the edge of the model instead of along it., like this
So the tool will leave indentations on the inner edge, like this
Why does the toolpath do this?  How can I make it behave 'normally' - where a rectangluar pocket is cut out with the tool following the direction of the edges of the model?
Thanks!
laughingcreek
you could make a manufacturing model and remove that stepdown.
rj_gould
Thank you.  I am not familiar with what you've done here but I will have a look at the file you attached and see what's what.
Much appreciated 🙂
