how to make multiple sheet metal bodies in a design into a 2d DXF
jwhiteF8NZC
Message 1 of 8
jwhiteF8NZC
hello i am trying to take all the sheet metal parts i have in my design and make them into a 2d pattern DXF to cut out on a plasma table but seem to be over complicating it and would like to know if i can even do that as a group or what is the most efficient way to do it. i have tried create flat pattern but seem to be doing it wrong. i have attached a image of the project for reference. thank you for your time.
Replies (7)
Message 2 of 8
TheCADWhisperer
@jwhiteF8NZC
Are you using Personal License or are you using Commercial License?
Message 3 of 8
jwhiteF8NZC
Hello Mr. Whisperer,
thank you for responding. i have a commercial account i believe, i checked and it just says legacy so not sure but this project is personal and is not intended to be sold.
Message 4 of 8
Warmingup1953
OK I have your file. Are you simply plasma cutting flat parts or will you be using a brake press to bend?
Message 5 of 8
jwhiteF8NZC
going to plasma cut everything that is flat and weld it all together. bout the only things I'm not cutting on the plasma are the legs, exhaust stack and lifting arms.
Message 6 of 8
jwhiteF8NZC
hello were you able to take a look at my issue? i was just looking for instruction on how to do it and not for you to do it for me if that helps.
Message 7 of 8
rosie_lucas1
Hi @jwhiteF8NZC
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Rosie | Community Manager
Message 8 of 8
jwhiteF8NZC
Hello Rosie,
no i have yet to hear back from any of the commentors and have not yet found a solution. i only need to know how to do it not for someone to do it for me.
